[Swift-devel] Re: swift testing of gram5 on teraport
    Michael Wilde
    wilde at mcs.anl.gov
    Fri Jun 19 11:17:04 CDT 2009
On 6/19/09 11:02 AM, Stuart Martin wrote:
> On Jun 19, 2009, at Jun 19, 10:54 AM, Michael Wilde wrote:
>> We'll find a way to do this, STu, but it may go a little slower than
>> desired due to heavy multi-tasking in the group.
>> So you should push forward to get it testable, thats step zero I think.
> I am pushing forward with groups where there is someone to drive the
> testing.  For example, Jaime Frey is testing gram5 with condor-g.  CMS
> will be doing some testing in early July.  Then there is the swift
> testing...
Stu,
I would suggest not to delay on getting it installed where we can test
with swift. My prior comment was based on a poor initial guess of whts
involved. But that's your call; when its installed where we can run
Swift jobs, we'll test it.
Eg: we are running 2 apps on Firefly at the moment. if you can get it
installed there, we can test on it even simpler than we are testing over
Condor-G.
Do you have a way to capture gatekeeper stress during such tests?
- Mike
>> In parallel, we should discuss on the list what ifany Swift changes
>> are needed to use it. It dont have my head around the issue at the
>> moment. Where can we read the specs of how it affects the user?
>> We have a pretty swamped schedule through July, so I'd expect to slot
>> this for late Jul early Aug.
>> Thanks,
>> Mike
>> On 6/19/09 10:21 AM, Stuart Martin wrote:
>>> Hi Mike,
>>> Ben was planning on testing GRAM5 on teraport for Swift.  Now that
>>> Ben is moving on, I am wondering what the plan is for that.  Do you
>>> still plan to do that?  Is there someone else that will do the testing?
>>> Ti was going to install GRAM5 for Ben to try out, but he has been
>>> delayed dealing with other issues.  GRAM5 has not yet been installed
>>> on teraport.  I was going to ask him again to install it, but I don't
>>> know who will now drive this testing.
>>> -Stu
