[Swift-devel] Re: swift testing of gram5 on teraport
    Stuart Martin
    smartin at mcs.anl.gov
    Fri Jun 19 11:02:33 CDT 2009
On Jun 19, 2009, at Jun 19, 10:54 AM, Michael Wilde wrote:
> We'll find a way to do this, STu, but it may go a little slower than
> desired due to heavy multi-tasking in the group.
> So you should push forward to get it testable, thats step zero I
> think.
I am pushing forward with groups where there is someone to drive the
testing.  For example, Jaime Frey is testing gram5 with condor-g.  CMS
will be doing some testing in early July.  Then there is the swift
testing...
> In parallel, we should discuss on the list what ifany Swift changes
> are needed to use it. It dont have my head around the issue at the
> moment. Where can we read the specs of how it affects the user?
> We have a pretty swamped schedule through July, so I'd expect to
> slot this for late Jul early Aug.
> Thanks,
> Mike
> On 6/19/09 10:21 AM, Stuart Martin wrote:
>> Hi Mike,
>> Ben was planning on testing GRAM5 on teraport for Swift.  Now that
>> Ben is moving on, I am wondering what the plan is for that.  Do you
>> still plan to do that?  Is there someone else that will do the
>> testing?
>> Ti was going to install GRAM5 for Ben to try out, but he has been
>> delayed dealing with other issues.  GRAM5 has not yet been
>> installed on teraport.  I was going to ask him again to install it,
>> but I don't know who will now drive this testing.
>> -Stu
