[Swift-devel] Re: [CI Ticketing System #1074] How to set .soft and env to run condor on TeraPort? (fwd)
Michael Wilde wilde at mcs.anl.gov
Fri Jun 19 11:13:16 CDT 2009
Zhao, when the best way for regular users to do this is determined
(sounds like its close) please put instructions for how to do it on:
http://www.ci.uchicago.edu/wiki/bin/view/SWFT
as page SwiftQuickStartForCondorG
(including all the Swift config issues, eg sites.xml, etc)
Mike
ps. I think you have a few other pages that should go there, eg, BGP,
Ranger/Coasters, etc.
How to run on your own local PBS cluster
On 6/19/09 11:07 AM, Ben Clifford wrote:
> ci support got removed from this thread but I believe this is relevant.
> Zhao also reports the same way of getting it working, in another
> non-ci-support message.
> ---------- Forwarded message ----------
> Date: Fri, 19 Jun 2009 16:00:13 +0000 (GMT)
> From: Ben Clifford <benc at hawaga.org.uk>
> To: Glen Hocky <support at ci.uchicago.edu>
> Cc: wilde at mcs.anl.gov, sthapa at ci.uchicago.edu, swift-devel at ci.uchicago.edu,
>     zhaozhang at uchicago.edu, papka at ci.uchicago.edu
> Subject: Re: [CI Ticketing System #1074] How to set .soft and env to run  condor
>      on TeraPort?
> my experience on tp-osg is that sourcing /opt/osg/setup.sh makes condor
> work. this suggests perhaps that in a working environment, condor should
> be coming from that OSG stack and not from a specific condor softenv key.
