[Swift-devel] Re: [CI Ticketing System #1074] How to set .soft and	env to run condor on TeraPort? (fwd)
    Ben Clifford
    support at ci.uchicago.edu
    Fri Jun 19 11:07:02 CDT 2009
ci support got removed from this thread but I believe this is relevant.
Zhao also reports the same way of getting it working, in another
non-ci-support message.
---------- Forwarded message ----------
Date: Fri, 19 Jun 2009 16:00:13 +0000 (GMT)
To: Glen Hocky <support at ci.uchicago.edu>
Cc: wilde at mcs.anl.gov, sthapa at ci.uchicago.edu, swift-devel at ci.uchicago.edu,
    zhaozhang at uchicago.edu, papka at ci.uchicago.edu
Subject: Re: [CI Ticketing System #1074] How to set .soft and env to run  condor
     on TeraPort?
my experience on tp-osg is that sourcing /opt/osg/setup.sh makes condor
work. this suggests perhaps that in a working environment, condor should
be coming from that OSG stack and not from a specific condor softenv key.
