[Swift-devel] [Fwd: [teraport-notify] tp-login2 job submission	failures]
    Michael Wilde
    wilde at mcs.anl.gov
    Wed Jun  3 16:24:08 CDT 2009
just fyi
-------- Original Message --------
Subject: [teraport-notify] tp-login2 job submission failures
Date: Wed, 3 Jun 2009 14:56:34 -0500
To: teraport-notify at ci.uchicago.edu
Users have reported failures when attempting job submissions to
Teraport's scheduler using the "qsub" command.  This problem has been
isolated to the node tp-login2.ci.uchicago.edu.  The cause for these
failures stem from recent misconfigurations in DNS service, which is
out of the CI's scope of control.  You will receive notification when
the responsible authority has corrected the misconfigurations.
In the meantime, all users should use tp-login1.ci.uchicago.edu
exclusively for job submission purposes.
teraport-notify mailing list
http://mail.ci.uchicago.edu/mailman/listinfo/teraport-notify
