[Swift-devel] Swift trunk seems to be broken
    Michael Wilde
    wilde at mcs.anl.gov
    Mon Jul 27 23:51:56 CDT 2009
I think its cog rev 2440 thats causing the problem.
2440 fails:
com$ swift t3.swift
Swift svn swift-r3021 cog-r2440
RunID: 20090727-2333-dpf7v3ze
Execution failed:
	org.globus.cog.karajan.workflow.KarajanRuntimeException: Could not
convert value to number: unbounded
Caused by:
	For input string: "unbounded"
com$ cd -
/home/wilde/swift/src/cog/modules/swift
com$
com$
2339 works:
com$ swift t3.swift
Swift svn swift-r3021 cog-r2439
RunID: 20090727-2337-g19sgr5f
com$
2440 is:
com$ svn diff -r 2439:2440
Index:
modules/karajan/src/org/globus/cog/karajan/workflow/nodes/functions/Misc.java
(revision 2439)
(revision 2440)
@@ -84,7 +84,13 @@
  	public boolean sys_equals(VariableStack stack) throws
ExecutionException {
  		Object[] args = getArguments(ARGS_2VALUES, stack);
-		return args[0].equals(args[1]);
+		if (args[0] instanceof Number) {
+			Number n2 = TypeUtil.toNumber(args[1]);
+			return ((Number) args[0]).doubleValue() == n2.doubleValue();
+		else {
+			return args[0].equals(args[1]);
Exception in log (example) is below.
- Mike
2009-07-27 21:36:28,559-0500 INFO  unknown Swift svn swift-r3019 (swift
modified locally) cog-r2445
2009-07-27 21:36:28,561-0500 INFO  unknown RUNID
id=tag:benc at ci.uchicago.edu,2007:swift:run:20090727-2136-ibeu4gif
2009-07-27 21:36:28,719-0500 DEBUG VDL2ExecutionContext
Caused by: org.globus.cog.karajan.workflow.KarajanRuntimeException:
Could not convert value to number: unbounded
         at org.globus.cog.karajan.util.TypeUtil.toNumber(TypeUtil.java:61)
         at
org.globus.cog.karajan.workflow.nodes.functions.Misc.sys_equals(Misc.java:88)
         at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
         at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:85)
         at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:58)
         at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:60)
         at java.lang.reflect.Method.invoke(Method.java:391)
         at
org.globus.cog.karajan.workflow.nodes.functions.FunctionsCollection.function(FunctionsCollection.java:78)
         at
org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:45)
         at
org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.childCompleted(AbstractSequentialWithArguments.java(Compiled
Code))
         at
org.globus.cog.karajan.workflow.nodes.Sequential.notificationEvent(Sequential.java(Compiled
Code))
         at
org.globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java(Compiled
Code))
         at
org.globus.cog.karajan.workflow.events.EventBus.send(EventBus.java(Compiled
Code))
         at
org.globus.cog.karajan.workflow.events.EventBus.sendHooked(EventBus.java(Compiled
Code))
         at
org.globus.cog.karajan.workflow.nodes.FlowNode.fireNotificationEvent(FlowNode.java(Compiled
Code))
         at
org.globus.cog.karajan.workflow.nodes.FlowNode.complete(FlowNode.java(Compiled
Code))
         at
org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.executeChildren(AbstractFunction.java:37)
         at
org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java(Compiled
Code))
         at
org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java(Compiled
Code))
         at
org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java(Inlined
Compiled Code))
         at
org.globus.cog.karajan.workflow.nodes.FlowNode.controlEvent(FlowNode.java(Compiled
Code))
         at
Code))
         at
org.globus.cog.karajan.workflow.FlowElementWrapper.event(FlowElementWrapper.java(Compiled
Code))
         at
Code))
         at
org.globus.cog.karajan.workflow.events.EventBus.sendHooked(EventBus.java(Inlined
Compiled Code))
         at
org.globus.cog.karajan.workflow.events.EventWorker.run(EventWorker.java(Compiled
Code))
Caused by: java.lang.NumberFormatException: For input string: "unbounded"
         at
java.lang.NumberFormatException.forInputString(NumberFormatException.java(Compiled
Code))
         at
java.lang.FloatingDecimal.readJavaFormatString(FloatingDecimal.java(Compiled
Code))
         at java.lang.Double.valueOf(Double.java:227)
         at org.globus.cog.karajan.util.TypeUtil.toNumber(TypeUtil.java:51)
         ... 25 more
On 7/27/09 11:21 PM, Michael Wilde wrote:
> This script:
> com$ cat >t3.swift
> type d {
>   int x;
> com$
> Gives:
> com$ swift t3.swift
> Swift svn swift-r3019 cog-r2445
> RunID: 20090727-2313-2zka71if
> Execution failed:
> Caused by:
> com$
> com$ java -version
> java version "1.5.0_06"
> Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_06-b05)
> Java HotSpot(TM) Server VM (build 1.5.0_06-b05, mixed mode)
> com$
> Is anyone else seeing this problem?
> This fails for me on both communicado and on the BG/P.
> On the BG/P I tried with both Java 2.4 and Java 6; both failed the same
> way.
> - Mike
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
