[Swift-devel] Swift trunk seems to be broken
Michael Wilde
wilde at mcs.anl.gov
Mon Jul 27 23:21:52 CDT 2009
This script:
com$ cat >t3.swift
type d {
int x;
com$
Gives:
com$ swift t3.swift
Swift svn swift-r3019 cog-r2445
RunID: 20090727-2313-2zka71if
Execution failed:
org.globus.cog.karajan.workflow.KarajanRuntimeException: Could not
convert value to number: unbounded
Caused by:
For input string: "unbounded"
com$
com$ java -version
java version "1.5.0_06"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_06-b05)
Java HotSpot(TM) Server VM (build 1.5.0_06-b05, mixed mode)
com$
Is anyone else seeing this problem?
This fails for me on both communicado and on the BG/P.
On the BG/P I tried with both Java 2.4 and Java 6; both failed the same way.
- Mike
