[Swift-devel] Fwd: [gram-user] GRAM5 Alpha2
Tiberiu Stef-Praun
tiberius at ci.uchicago.edu
Tue Jul 21 11:05:28 CDT 2009
Hi Stu
I was just installing yesterday my application on queenbee. So I could
do some testing for you, just let me know how to take advantage of the
new GRAM5
Does cogkit/swift already support GRAM5 ?
Tibi
On Tue, Jul 21, 2009 at 10:58 AM, Stuart Martin<smartin at mcs.anl.gov> wrote:
> Are there any swift apps that can use queen bee? There is a GRAM5 service
> setup there for testing.
> -Stu
> Begin forwarded message:
>> From: Stuart Martin <smartin at mcs.anl.gov>
>> Date: July 21, 2009 10:56:04 AM CDT
>> To: gateways at teragrid.org
>> Cc: Stuart Martin <smartin at mcs.anl.gov>, Lukasz Lacinski
>> <lukas at cct.lsu.edu>
>> Subject: Fwd: [gram-user] GRAM5 Alpha2
>> Hi Gateways,
>> Any gateways that use (or can use) Queen Bee, it would be great if you
>> could target this new GRAM5 service that Lukasz deployed. I heard from
>> Lukasz that Jim has submitted a gateway user (SAML) job and that went
>> through fine and populate the gram audit DB correctly. Thanks Jim! It
>> would be nice to have some gateway push the service to test scalability.
>> Let us know if you plan to do this.
>> Thanks,
>> Stu
>>> From: Lukasz Lacinski <lukas at cct.lsu.edu>
>>> Date: July 21, 2009 1:18:05 AM CDT
>>> To: gram-user at lists.globus.org
>>> Subject: [gram-user] GRAM5 Alpha2
>>> I've installed GRAM5 Alpha2 on Queen Bee.
>>> queenbee.loni-lsu.teragrid.org:2120/jobmanager-fork
>>> queenbee.loni-lsu.teragrid.org:2120/jobmanager-pbs
>>> -seg-module pbs works fine.
>>> GRAM audit with PostgreSQL works fine.
>>> Can someone submit jobs as a gateway user? I'd like to check if the
>>> gateway_user field is written to our audit database.
>>> Thanks,
>>> Lukasz
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Tiberiu (Tibi) Stef-Praun, PhD
Computational Sciences Researcher
Computation Institute
5640 S. Ellis Ave, #405
University of Chicago
http://www-unix.mcs.anl.gov/~tiberius/
