[Swift-devel] Fwd: [gram-user] GRAM5 Alpha2
    Stuart Martin
    smartin at mcs.anl.gov
    Tue Jul 21 10:58:15 CDT 2009
Are there any swift apps that can use queen bee?  There is a GRAM5
service setup there for testing.
-Stu
Begin forwarded message:
> From: Stuart Martin <smartin at mcs.anl.gov>
> Date: July 21, 2009 10:56:04 AM CDT
> To: gateways at teragrid.org
> Cc: Stuart Martin <smartin at mcs.anl.gov>, Lukasz Lacinski <lukas at cct.lsu.edu
> Subject: Fwd: [gram-user] GRAM5 Alpha2
> Hi Gateways,
> Any gateways that use (or can use) Queen Bee, it would be great if
> you could target this new GRAM5 service that Lukasz deployed.  I
> heard from Lukasz that Jim has submitted a gateway user (SAML) job
> and that went through fine and populate the gram audit DB
> correctly.  Thanks Jim!  It would be nice to have some gateway push
> the service to test scalability.
> Let us know if you plan to do this.
> Thanks,
> Stu
>> From: Lukasz Lacinski <lukas at cct.lsu.edu>
>> Date: July 21, 2009 1:18:05 AM CDT
>> To: gram-user at lists.globus.org
>> Subject: [gram-user] GRAM5 Alpha2
>> I've installed GRAM5 Alpha2 on Queen Bee.
>> queenbee.loni-lsu.teragrid.org:2120/jobmanager-fork
>> queenbee.loni-lsu.teragrid.org:2120/jobmanager-pbs
>> -seg-module pbs works fine.
>> GRAM audit with PostgreSQL works fine.
>> Can someone submit jobs as a gateway user? I'd like to check if the
>> gateway_user field is written to our audit database.
>> Thanks,
>> Lukasz
