[Swift-devel] Coasters and std's on ranger
    skenny at uchicago.edu
    Tue Jul 14 10:11:40 CDT 2009
>I see. What happens is that redirection hasn't been fixed in
SGE, but
>the commenting out of it in the gt2 provider did nothing
because it was
>enabled in the coaster provider.
right, i must've misunderstood, i had commented out
redirection for the gt2 provider so swift would work for
running w/o coasters, but i thought you were saying cog r2430
would be also redirecting for coasters as well...but
apparently you were trying a different change?
>There is one more thing to try, and that is to re-direct to a
remote
>file, hoping it won't hit whatever problem it hits now.
so, can you tell me where in the code i can redirect std's for
coasters? or, are you saying something else? :P
>On Tue, 2009-07-14 at 02:05 -0500, skenny at uchicago.edu wrote:
>> >I see that in the current coaster code the stdout of the
>> block task is
>> >always redirected.
>> >Try cog r2430 and keep the commented lines commented in
the gt2
>> >provider.
>> 2009-07-14 01:14:30,525-0500 INFO  unknown Swift svn
>> swift-r3005 cog-r2430 (cog modified locally)
>> Execution failed:
>>         Exception in RInvoke:
>> Arguments: [scripts/4reg_dummy.R,
>> matrices/4_reg/network1/gestspeech.cov, 2, 0.5, speech]
>> Host: RANGER
>> Directory:
>> 4reg_speech-20090714-0114-ad0vxv90/jobs/z/RInvoke-zlbzzmdj
>> stderr.txt:
>> stdout.txt:
>> Caused by:
>>         Block task failed: 0714-140152-000000Block task ended
>> prematurely
>> Progress:  Submitted:18  Failed:16  Finished successfully:16
>> Cleaning up...
>> gram log:
>> 7/14 01:25:44 JM: sending callback of status 4 (failure code
>> 155) to https://128.135.125.211:50003/1247552072425.
>> 7/14 01:25:44 JMI: testing job manager scripts for type fork
>> exist and permissions are ok.
