[Swift-devel] Coaster CPU-time consumption issue
skenny at uchicago.edu skenny at uchicago.edu
Mon Jul 13 17:41:50 CDT 2009
cool, i'll give this a shot now too.
it's possible the other err i mentioned to you mike, was
actually related to the stdout redirection. i wanted to test
more, but trying not to wreak havoc on the headnode :P anyway,
if this works, i can do more testing and will post if i'm
still getting the error.
~sk
---- Original message ----
>Date: Mon, 13 Jul 2009 17:17:26 -0500
>From: Michael Wilde <wilde at mcs.anl.gov>
>Subject: Re: [Swift-devel] Coaster CPU-time consumption issue
>To: Allan Espinosa <aespinosa at cs.uchicago.edu>, Sarah Kenny
<skenny at uchicago.edu>
>Cc: swift-devel <swift-devel at ci.uchicago.edu>
>Nice!  Now lets beat it up and see how well it works.
>Sarah: Allan did not encounter the error messages you
mentioned to me.
>I suggest you do this:
>- post to the devel list the messages you got
>- test this patch to see if it clears up the problem
>Mike
>On 7/13/09 5:04 PM, Allan Espinosa wrote:
>> hi,
>> here is a patch which solves the cpu usage on the bootstrap
coaster
>> service:
http://www.ci.uchicago.edu/~aespinosa/provider-coaster-cpu_fix.patch
>> suggested svn log entry:
>>     Added locks via wait() and notify() to prevent busy
waiting/
>> active polling in the block task queue.
>> Test 2000 touch job using 066-many.swift via local:local :
>> before: http://www.ci.uchicago.edu/~aespinosa/swift/run06
>> after: http://www.ci.uchicago.edu/~aespinosa/swift/run07
>> CPU usage drops from 100% to 0% with a few 25-40 % spikes!
>> -Allan
>> 2009/7/13 Michael Wilde <wilde at mcs.anl.gov>:
>>> Hi Allan,
>>> I think the methods you want for synchronization are part
of class Object.
>>> They are documented in the chapter Threads and Locks of
The Java Language
>>> Specification:
http://java.sun.com/docs/books/jls/third_edition/html/memory.html#17.8
>>> queue.wait() should be called if the queue is empty.
>>> queue.notify() or .notifyall() should be called when
something is added to
>>> the queue. I think notify() should work.
>>> .wait will I think take a timer, but suspect you dont need
that.
>>> Both should be called within the synchronized(queue)
constructs that are
>>> already in the code.
>>> Should be fun to fix this!
>>> - Mike
>>> On 7/13/09 2:12 PM, Allan Espinosa wrote:
>>>> 97% is an average as can be seen in run06.  swift version
is r3005 and
>>>> cogkit r2410.  this is a vanilla build of swift.
>>>> 2009/7/13 Mihael Hategan <hategan at mcs.anl.gov>:
>>>>> A while ago I committed a patch to run the service
process with a lower
>>>>> priority. Is that in use?
>>>>> Also, is logging reduced or is it the default?
>>>>> Is the 97% CPU usage a spike, or does it stay there on
average?
>>>>> Can I take a look at the coaster logs from skenny's run
on ranger?
>>>>> I'd also like to point out in as little offensive mode
as I can, that
>>>>> I'm working 100% on I2U2 and my lack of getting more
than lightly
>>>>> involved in this is a consequence of that.
>>>>> On Mon, 2009-07-13 at 13:55 -0500, Allan Espinosa wrote:
>>>>>> I ran 2000 "sleep 60" jobs on teraport and monitored
tp-osg.  From
>>>>>> here process 22395 is the child of the main java process
>>>>>> (bootstrap.jar) and is loading the CPU.
>>>>>> I have coasters.log, worker-*log, swift logs, gram logs in
>>>>>> ~aespinosa/workflows/activelog/run06.  This refers to a
different run.
>>>>>>  PID 15206 is the child java process of bootstrap.jar
in here.
>>>>>> top snapshot:
>>>>>> top - 13:49:03 up 55 days,  1:45,  1 user,  load
average: 1.18, 0.80,
>>>>>> 0.55
>>>>>> Tasks: 121 total,   1 running, 120 sleeping,   0
stopped,   0 zombie
>>>>>> Cpu(s):  7.5%us,  2.8%sy, 48.7%ni, 41.0%id,  0.0%wa,
0.0%hi,  0.0%si,
>>>>>>  0.0%st
>>>>>> Mem:   4058916k total,  3889864k used,   169052k free,
  239688k buffers
>>>>>> Swap:  4192956k total,       96k used,  4192860k free,
 2504812k cached
>>>>>>  PID USER      PR  NI  VIRT  RES  SHR S %CPU %MEM
TIME+  COMMAND
>>>>>> 22395 aespinos  25  10  525m  91m  13m S 97.5  2.3
4:29.22 java
>>>>>> 22217 aespinos  15   0 10736 1048  776 R  0.3  0.0
0:00.50 top
>>>>>> 22243 aespinos  16   0  102m 5576 3536 S  0.3  0.1
0:00.10
>>>>>> globus-job-mana
>>>>>> 14764 aespinos  15   0 98024 1744  976 S  0.0  0.0
0:00.06 sshd
>>>>>> 14765 aespinos  15   0 65364 2796 1176 S  0.0  0.1
0:00.18 bash
>>>>>> 22326 aespinos  18   0  8916 1052  852 S  0.0  0.0
0:00.00 bash
>>>>>> 22328 aespinos  19   0  8916 1116  908 S  0.0  0.0
0:00.00 bash
>>>>>> 22364 aespinos  15   0 1222m  18m 8976 S  0.0  0.5
0:00.20 java
>>>>>> 22444 aespinos  16   0  102m 5684 3528 S  0.0  0.1
0:00.09
>>>>>> globus-job-man
>>>>>> ps snapshot:
>>>>>> 22328 ?        S      0:00  \_ /bin/bash
>>>>>> 22364 ?        Sl     0:00      \_
>>>>>> /opt/osg-ce-1.0.0-r2/jdk1.5/bin/java
>>>>>> -Djava=/opt/osg-ce-1.0.0-r2/jdk1.5/bin/java
-DGLOBUS_TCP_PORT_RANGE=
-DX509_USER_PROXY=/home/aespinosa/.globus/job/tp-grid1.ci.uchicago.edu/22243.1247510668/x509_up
>>>>>> -DX509_CERT_DIR=
-DGLOBUS_HOSTNAME=tp-osg.ci.uchicago.edu -jar
>>>>>> /tmp/bootstrap.w22332
http://communicado.ci.uchicago.edu:46520
>>>>>> https://128.135.125.17:46519 11505253269
>>>>>> 22395 ?        SNl    6:29          \_
>>>>>> /opt/osg-ce-1.0.0-r2/jdk1.5/bin/java -Xmx128M
>>>>>> -Djava.security.egd=file:///dev/urandom -cp
/home/aespinosa/.globus/coasters/cache/cog-provider-coaster-0.3-e10824578d296f9eebba24f209dbed7b.jar:/home/aespinosa/.globus/coasters/cache/backport-util-concurrent-f9c59530e5d6ca38f3ba6c0b6213e016.jar:/home/aespinosa/.globus/coasters/cache/cog-abstraction-common-2.3-6f32fedfa8ec01e07d0096a5275ac24b.jar:/home/aespinosa/.globus/coasters/cache/cog-jglobus-dev-080222-d87a8fb09be6d8011f6492feabce475d.jar:/home/aespinosa/.globus/coasters/cache/cog-karajan-0.36-dev-1614e96028db0b862d84fa01e5998872.jar:/home/aespinosa/.globus/coasters/cache/cog-provider-gt2-2.4-b8ed4d13933b4c28a7e6844a39a4fad3.jar:/home/aespinosa/.globus/coasters/cache/cog-provider-gt4_0_0-2.5-658d743844fc772713ac2aa6f92b00e7.jar:/home/aespinosa/.globus/coasters/cache/cog-provider-local-2.2-60cc44c1599e1298376036bb9dc531c7.jar:/home/aespinosa/.globus/coasters/cache/cog-provider-localscheduler-0.4-c5eeab454e4fe4a99421e28761566bf1.jar:/home/aespinosa/.globus/coasters/cache/cog-provider-ssh-2.4-74d67b067ac196fcde
>c9
46b9584af140.jar:/home/aespinosa/.globus/coasters/cache/cog-util-0.92-7b1f1e2bf52a6b575948e3f8949fa1df.jar:/home/aespinosa/.globus/coasters/cache/cryptix-asn1-87c4cf848c81d102bd29e33681b80e8a.jar:/home/aespinosa/.globus/coasters/cache/cryptix-c3dad86be114c7aaf2ddf32c8e52184a.jar:/home/aespinosa/.globus/coasters/cache/cryptix32-59772ad239684bf10ae8fe71f4dbae22.jar:/home/aespinosa/.globus/coasters/cache/concurrent-967678fe1b153be98d982e3867e7271b.jar:/home/aespinosa/.globus/coasters/cache/j2ssh-core-0.2.2-patched-9bf1ffb8ab700234649f70ef4a35f029.jar:/home/aespinosa/.globus/coasters/cache/j2ssh-common-0.2.2-d65a51ea6f64efc066915c1618c613ca.jar:/home/aespinosa/.globus/coasters/cache/jaxrpc-8e7d80b5d77dff6ed2f41352e9147101.jar:/home/aespinosa/.globus/coasters/cache/jce-jdk13-131-06fc7049669d16c4001a452e100b401f.jar:/home/aespinosa/.globus/coasters/cache/jgss-9cccfd21259791b509af229a0181f207.jar:/home/aespinosa/.globus/coasters/cache/log4j-1.2.8-18a4ca847248e5b8606325684342701c.
>jar
:/home/aespinosa/.globus/coasters/cache/puretls-90b9c31c201243b9f4a24fa11d404702.jar:/home/aespinosa/.globus/coasters/cache/addressing-1.0-44c19ed929b7d8ab75812b7cd60753c7.jar:/home/aespinosa/.globus/coasters/cache/commonj-80b93fb3333a17d66fc1afdef5a13563.jar:/home/aespinosa/.globus/coasters/cache/axis-f01bcaa789cf9735430b289f6b39ea9a.jar:/home/aespinosa/.globus/coasters/cache/axis-url-fffc9e2378df340c8d3ed0c029867d0d.jar:/home/aespinosa/.globus/coasters/cache/cog-axis-eafb6cd78da733f3293a5508793c10a4.jar:/home/aespinosa/.globus/coasters/cache/globus_delegation_service-e49623aeb2d0297615dfb7ad5a834306.jar:/home/aespinosa/.globus/coasters/cache/globus_delegation_stubs-29ce051b29a9422aeba1f60ac205f1b1.jar:/home/aespinosa/.globus/coasters/cache/globus_wsrf_mds_aggregator_stubs-fbcd9a33c3982fae5a4231ca8f426560.jar:/home/aespinosa/.globus/coasters/cache/globus_wsrf_rendezvous_stubs-d09ea57f3863104dafca984682ec71ff.jar:/home/aespinosa/.globus/coasters/cache/globus_wsrf_rendezvou
>s_s
ervice-afc177c2e02fd0e773698f3d478a33ef.jar:/home/aespinosa/.globus/coasters/cache/globus_wsrf_rft_stubs-e3be33b222d03afc750b112c7f638f41.jar:/home/aespinosa/.globus/coasters/cache/gram-utils-ab1a282ee889d381b22051a863f086cb.jar:/home/aespinosa/.globus/coasters/cache/gram-stubs-1bd6f6863c3d4c31bf5aa0dd34adf0be.jar:/home/aespinosa/.globus/coasters/cache/gram-client-197210112784800e635b333acda58ee9.jar:/home/aespinosa/.globus/coasters/cache/naming-resources-d7a5b4123aad30d5dc11ca827aa6177a.jar:/home/aespinosa/.globus/coasters/cache/naming-common-1cfe69c9206c1f13bb328a350e3fb0e4.jar:/home/aespinosa/.globus/coasters/cache/naming-factory-ddb1fb5f295162e0389d713822f1112e.jar:/home/aespinosa/.globus/coasters/cache/naming-java-6f6855fb184b81d050d17a1e938cd2a2.jar:/home/aespinosa/.globus/coasters/cache/saaj-fa0706bd9bcb29f522c1a08db1cbcd94.jar:/home/aespinosa/.globus/coasters/cache/wsdl4j-a0f571fafc
>>>>>>> On Mon, 2009-07-13 at 12:28 -0500, Michael Wilde wrote:
>>>>>>>>>> At the time we did not have a chance to gather
detailed evidence,
>>>>>>>>>> but I
>>>>>>>>>> was surprised by two things:
>>>>>>>>>> - that there were two Java processes and that one
was so big. (Are
>>>>>>>>>> most
>>>>>>>>>> likely the active process was just a child thread
of the main
>>>>>>>>>> process?)
>>>>>>>>> One java process is the bootstrap process (it
downloads the coaster
>>>>>>>>> jars, sets up the environment and runs the coaster
service). It has
>>>>>>>>> always been like this. Did you happen to capture the
output of ps to
>>>>>>>>> a
>>>>>>>>> file? That would be useful, because from what you
are suggesting, it
>>>>>>>>> appears that the bootstrap process is eating 100%
CPU. That process
>>>>>>>>> should only be sleeping after the service is started.
>>>>>>>> I *thought* I captured the output of "top -u
sarahs'id -b -d" but I
>>>>>>>> cant
>>>>>>>> locate it.
>>>>>>>> As best as I can recall it showed the larger
memory-footprint process
>>>>>>>> to
>>>>>>>> be relatively idle, and the smaller footprint process
(about 275MB) to
>>>>>>>> be burning 100% of a CPU.
>>>>>>> Normally, the smaller footprint process should be the
bootstrap. But
>>>>>>> that's why I would like the ps output, because it
sounds odd.
>>>>>>>>  Allan will try to get a snapshot of this shortly.
>>>>>>>> If this observation if correct, whats the best way to
find out where
>>>>>>>> its
>>>>>>>> spinning? Profiling? Debug logging? Can you get
profiling data from a
>>>>>>>> JVM that doesnt exit?
>>>>>>> Once I know where it is, I can look at the code and
then we'll go from
>>>>>>> there.
