[Swift-devel] swift error ( gridftp problem)
yizhu
yizhu at cs.uchicago.edu
Wed Jul 1 15:42:31 CDT 2009
Yup, it's my firewall setting problem, now it works, Thanks.
-Yi
Ben Clifford wrote:
> this is almost definitely a firewall problem, with you not having the
> correct ports for gridftp data channels open.
> read this:
> http://dev.globus.org/wiki/FirewallHowTo
> You need to configure an ephemeral port range in your firewall, of maybe
> 1000 ports, and declare it in the GLOBUS_TCP_PORT_RANGE for your server,
> as described here:
> http://dev.globus.org/wiki/FirewallHowTo#Configuring_GridFTP_to_use_GLOBUS_TCP_PORT_RANGE
> Make sure you can transfer a file with globus-url-copy before attempting
> to run Swift.
> This is not a swift-specific problem.
