[Swift-devel] swift error ( gridftp problem)
    Ben Clifford
    benc at hawaga.org.uk
    Wed Jul  1 07:26:11 CDT 2009
this is almost definitely a firewall problem, with you not having the
correct ports for gridftp data channels open.
read this:
http://dev.globus.org/wiki/FirewallHowTo
You need to configure an ephemeral port range in your firewall, of maybe
1000 ports, and declare it in the GLOBUS_TCP_PORT_RANGE for your server,
as described here:
http://dev.globus.org/wiki/FirewallHowTo#Configuring_GridFTP_to_use_GLOBUS_TCP_PORT_RANGE
Make sure you can transfer a file with globus-url-copy before attempting
to run Swift.
This is not a swift-specific problem.
