[Swift-devel] Re: Coasters failing on Teraport - cant find Java?
    Ben Clifford
    benc at hawaga.org.uk
    Tue Jan 27 15:29:52 CST 2009
On Tue, 27 Jan 2009, Michael Wilde wrote:
> To clarify further: with coasters, is <gridftp url=local://localhost> a valid
> option?
> Ie, coasters has 3 valid data provider options: gridftp, local, and
> "filesystem" which uses the coasters themselves to move data?
use any one of those three.
> (Can you explain how the "filesystem" method works? I didnt find the
> userguide clear enough on that to help decide if/when to select this
> method)
<gridftp ...> is pretty much a synonym for <filesystem provider="gt2" ...>
So then consider the above three as different mechanisms using
<filesystem>, with:
provider="gt2" - use gridftp to transfer the file from where the Swift
command line client is running to the remote location
provider="local" - use posix filesystem access to transfer the file, which
only works where you have posix access to the 'remote' site shared
directory
provider="coaster" - execute a remote file server process (being part of
coaster) and through that access files on the remote site
