[Swift-devel] Re: Coasters failing on Teraport - cant find Java?
    Michael Wilde
    wilde at mcs.anl.gov
    Tue Jan 27 15:25:13 CST 2009
I'll let Allan go for the chocolate bar :)
To clarify further: with coasters, is <gridftp url=local://localhost> a
valid option?
Ie, coasters has 3 valid data provider options: gridftp, local, and
"filesystem" which uses the coasters themselves to move data?
(Can you explain how the "filesystem" method works? I didnt find the
userguide clear enough on that to help decide if/when to select this method)
- Mike
On 1/27/09 3:16 PM, Ben Clifford wrote:
> On Tue, 27 Jan 2009, Allan Espinosa wrote:
>> For the sites.xml, I think you need to specify the filesystem provider
>> which sets up the environment for the coaster (based on what I
>> understood from the documentation).  Below is my sites.xml:
> Don't specify <filesystem> and <gridftp> - they are different ways of
> expressing the same configuration.
> On teraport, you shoudl be fine using the <gridftp> line that you showed:
>>     <gridftp
>> url="gsiftp://tp-grid1.ci.uchicago.edu/disks/tp-gpfs/scratch/aespinosa"
>> storage="/opt/osg/data/aespinosa" major="2" minor="2" patch="4">
>>     </gridftp>
> Specifying <gridftp> and <filesystem> at the same time is an error, and
> you get a chocolate bar if you file a bugzilla report that Swift does not
> correctly detect this (seriously).
