[Swift-devel] a note on running coasters on osg's RENCI Engage 	site
    Allan Espinosa
    aespinosa at cs.uchicago.edu
    Mon Jan 26 12:39:56 CST 2009
So in the current setup, the coaster service only binds to the public
address of the head node and not all the network devices?
On Mon, Jan 26, 2009 at 12:33 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> On Mon, 2009-01-26 at 12:28 -0500, Mats Rynge wrote:
>> Ben Clifford wrote:
>> > Coasters in the release don't work on RENCI Engage.
>> > I fiddled with this a bit before, and just fiddled with it a bit more.
>> > The external IP address of the cluster head node (152.54.1.231) is not
>> > accessible from the cluster worker nodes, which sit on a different
>> > network.
>> > The headnode *is* accessible from its IP address on that network,
>> > 192.168.1.11.
>> > Forcing the URI passed to workers to use that IP address instead of the
>> > automatically determined one is sufficient to make coasters work on the
>> > RENCI Engage site.
>> I'm surprised that the private address was not used already. I mean,
>> isn't this the use case for putting the coaster forwarder on the
>> headnode in the first place? If you have outbound network connectivity,
>> the coaster daemons in the worker nodes could connect directly to the
>> host where swift is running on.
> Automatically figuring out which eth should be used is a tricky thing
> given that cluster configurations don't seem to follow some
> pre-established rule. Each sites does stuff in their own way, though
> most seem to have the head node accessible internally through the public
> head node address.
