[Swift-devel] Re: fun with osg [Swift-devel Digest, Vol 23,	Issue 12]
    Ben Clifford
    benc at hawaga.org.uk
    Fri Jan 16 09:46:04 CST 2009
On Fri, 16 Jan 2009, Michael Wilde wrote:
> - can that script be run for other VOs such as OSG, OSGEDU?
yes. the results you will get for Engage will be higher quality than the
results that you get for other VOs, in as much as the sites file generated
for the Engage VO has sites filtered out based on additional testing done
periodically.
> - has progress been made on running coasters on OSG?
no
> - what are good settings for Swift without coasters to avoid overheating head
> nodes in the absence of Swift gridmonitor support?
I'd give the same advice that I give for any general use of GRAM2 - don't
set the job throttle to higher than 0.2; this will have a maximum of 20
jobs at once on a site.
> - what's the status of the swift-devel thread "Swift-devel] jobs that go
> active forever, and their effect on multisite osg runs" - any
> resolution?
There's a bugzilla ticket open but no implementation at the moment:
http://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=169
