[Swift-devel] Re: [Swift-user] Questions on use of iterate statement
    Michael Wilde
    wilde at mcs.anl.gov
    Wed Feb 25 08:07:42 CST 2009
On 2/23/09 9:46 AM, Ben Clifford wrote:
> As of r2593 you should be able to use the style of iteration that you
> originally used.
Thanks, Ben.
When I tried this, it turned out my data flow required a whole array of
results to be passed out of the iterate anyways. So what was initially a
workaround turned out to be the way it needed to be coded anyways. But
I'll try to test your change on other variants of this.
