[Swift-devel] different host CN expectations in gram and	gridftp  server
    Mihael Hategan
    hategan at mcs.anl.gov
    Tue Feb 24 15:17:59 CST 2009
Ok. I'll look into this.
On Tue, 2009-02-24 at 15:14 -0600, Allan Espinosa wrote:
> I still get the same gram authentication error message:
> Caused by: org.globus.cog.abstraction.impl.common.task.TaskSubmissionException:
> Cannot submit job
> Caused by: org.globus.gram.GramException: Data transfer to the server
> failed [Caused by: Authentication failed [Caused by: Operation
> unauthorized (Mechanism level: [JGLOBUS-56] Authorization failed.
> Expected "/CN=host/129.114.50.163" target but received
> "/C=US/O=UTAustin/OU=TACC/CN=login3.ranger.tacc.utexas.edu")]]
> 2009-02-24 15:12:07,215-0600 DEBUG vdl:execute2 APPLICATION_EXCEPTION
> jobid=hostname-8tx7p37j - Application exception: Cannot submit job
> This is using both the fork and sge job manager via gram2-only
> -aallan
> On Mon, Feb 23, 2009 at 10:58 AM, Ben Clifford <benc at hawaga.org.uk> wrote:
> > If you use gram2 instead of coasters+gram2, what happens?
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
