[Swift-devel] different host CN expectations in gram and gridftp 	server
    Allan Espinosa
    aespinosa at cs.uchicago.edu
    Tue Feb 24 15:14:23 CST 2009
I still get the same gram authentication error message:
Caused by: org.globus.cog.abstraction.impl.common.task.TaskSubmissionException:
Cannot submit job
Caused by: org.globus.gram.GramException: Data transfer to the server
failed [Caused by: Authentication failed [Caused by: Operation
unauthorized (Mechanism level: [JGLOBUS-56] Authorization failed.
Expected "/CN=host/129.114.50.163" target but received
"/C=US/O=UTAustin/OU=TACC/CN=login3.ranger.tacc.utexas.edu")]]
2009-02-24 15:12:07,215-0600 DEBUG vdl:execute2 APPLICATION_EXCEPTION
jobid=hostname-8tx7p37j - Application exception: Cannot submit job
This is using both the fork and sge job manager via gram2-only
-aallan
On Mon, Feb 23, 2009 at 10:58 AM, Ben Clifford <benc at hawaga.org.uk> wrote:
> If you use gram2 instead of coasters+gram2, what happens?
