[Swift-devel] absolute path
Ben Clifford
benc at hawaga.org.uk
Sat Feb 21 08:11:03 CST 2009
On Fri, 20 Feb 2009, Zhao Zhang wrote:
> The context on BGP is, the working "sleep-20090220-1646-7vdlcg0a" directory is
> created on IO nodes at
> "/tmp/sleep-20090220-1646-7vdlcg0a/", and mounted on Compute Node through
> fuse. which means Compute Nodes
> need to enter this directory through /fuse/tmp/sleep-20090220-1646-7vdlcg0a,
> then with the old style of relative path
> "shared/wrapper.sh", everything is fine. And the wrapper.sh knows where the
> job is started, so all output data will be
> copied to the job dir on IO nodes.
ok, I'll make a config option to allow you to choose whether wrapper.sh is
invoked with an absolute path in the command line or not.
