[Swift-devel] Status of coasters
    Ioan Raicu
    iraicu at cs.uchicago.edu
    Fri Feb 13 12:51:24 CST 2009
I think we are on the same page, as I was not implying to use methods to
bypass accounting or lrm policies.
Cheers,
Ioan
Mats Rynge wrote:
> Ioan Raicu wrote:
>> Although, we and others have been doing this (multi-level scheduling)
>> for a while now, using Coasters, Falkon, Condor glide-ins, etc... I
>> don't see what would be different, to set up a separate WS-GRAM
>> interface on a site that doesn't support it. Its just another method, to
>> do multi-level scheduling.
> No. The problem here is that you want to directly interact with the lrm.
> This will break several things such as accounting, and lrm policies. It
> is similar to use jobmanger-fork to run condor_submit. Even though it is
> technically possibly to do so, most OSG sites would find such a behavior
> unacceptable and probably ban the user/VO doing it.
> This is different from for example glideins, where you use the existing
> interface and lrm to get slots allocated to you, and then your job is
> actually the glidein. The WS-GRAM on the side would be the same iif you
> submitted it to the lrm, started it on compute nodes and only used
> jobmanager-fork (but only one real job at once). This would obviously
> not be very helpful as many compute nodes are behind NAT.
> You really should not user jobmanager-fork for anything except simple
> setup/cleanup jobs.
Ioan Raicu, Ph.D.
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web:   http://www.cs.uchicago.edu/~iraicu
http://dev.globus.org/wiki/Incubator/Falkon
http://dsl-wiki.cs.uchicago.edu/index.php/Main_Page
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20090213/11f5532d/attachment.html>
