[Swift-devel] Status of coasters
Michael Wilde wilde at mcs.anl.gov
Fri Feb 13 10:05:18 CST 2009
Stu, this would be a good thing to discuss through the UChicago OSG
group. I can start that, and am cc'ing Rob Gardner to get it on the list
of Globus-OSG things to track.
- Mike
 > But also, we want to have GRAM2 sites to start to use the SEG to remove
 > a significant portion of the GRAM2 scalability problem.  I think that
 > would be best and simplest solution to focus on.  Maybe we can start
 > with a site where you need more scalability and the admin would want to
 > work with us on that?
- Mike
On 2/13/09 9:58 AM, Stuart Martin wrote:
> On Feb 13, 2009, at Feb 13, 9:40 AM, Tim Freeman wrote:
>> On Fri, 13 Feb 2009 09:32:43 -0600
>> Mihael Hategan <hategan at mcs.anl.gov> wrote:
>>> On Fri, 2009-02-13 at 09:23 -0600, Michael Wilde wrote:
>>>> On 2/13/09 9:17 AM, Mihael Hategan wrote:
>>>>> On Fri, 2009-02-13 at 08:59 -0600, Michael Wilde wrote:
>>>>>> -- Service submits via WS-GRAM. This should be tested, on sites
>>>>>> whereWS-GRAM is working.
>>>>>> This woild use jobmanager=gt2:gt4:{pbs/condor/sge}, and needs to be
>>>>>> tested. For sites where WS-GRAM is not functional, I suggested we
>>>>>> consider configuring our own non-root WS-GRAM, ideally using
>>>>>> already-installed GT4 software, eg, from the OSG package on OSG
>>>>>> and TG
>>>>>> sites where its installed. Mihael thought this would be considerable
>>>>>> work.
>>>>> Not as much the amount of work, but:
>>>>> 1. getting root on sites (if installed for multiple users)
>>>> I was thinking/hoping we could have a single setup script, which we'd
>>>> pre-install where required, that would configure and start a personal
>>>> WSRF container for the user. Which would be work for us to create,
>>>> install and maintain, but, if successful, would be transparent to
>>>> the user.
>>> You need root to configure sudo.
>> Why would you need sudo for gram if it mapped to the same account?
> You wouldn't.  sudo is not needed if the DN of the requester is the same
> as the DN used to start the container.
>>> I also don't think you can easily automate the gt4 installation process.
>>> There's manual configuration that needs to be done. I suggest installing
>>> your own gt4 once to which I can submit jobs to get an idea of what's
>>> involved.
>> For non-gram, there's an auto script here:
>> http://workspace.globus.org/vm/TP2.2/admin/quickstart.html#auto-container
>> The questions it asks users (is this the right hostname? etc) could
>> also be
>> scripted.
>> Getting from there to GRAM4 auto-configuration should not be too much
>> of a step
>> (the nimbus contextualization scripts have done it for gram4).
> You could do this and if you avoid staging, then this may work fine for
> GRAM4.
>> Tim
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
