[Swift-devel] Problems with coasters and managedfork jobmanager
Mihael Hategan hategan at mcs.anl.gov
Tue Feb 10 23:43:25 CST 2009
On Tue, 2009-02-10 at 22:54 -0600, Michael Wilde wrote:
> Sorry, I still dont get it. Did the globusrun command below work for
> you? It doesnt work for me, and doesnt match the syntax of what I
> understand globusrun to expect.
Allow me to rephrase it. Try the globusrun command that does "perl -e
<contents of that file>". I haven't tried it, so I don't know the exact
incantation.
> I was not able to get coaster-bootstrap.jar.pl into an RSL string for
> globusrun. I don't think thats possible, because globusrun gets confused
> by the single and double quotes in that file.
Globusrun should properly escape those as long as it is gets the correct
ARGV (which '`cat file`' should do).
> Unless Im missing something, as far as I can tell you can only test this
> from API level. Has it worked for you, from inside swift, say from
> ServiceManager?
I haven't tried it from inside swift. I'll poke around and send a
command that can be used literally.
