[Swift-devel] Problems with coasters and managedfork jobmanager
Mihael Hategan
hategan at mcs.anl.gov
Tue Feb 10 20:22:54 CST 2009
----- Michael Wilde <wilde at mcs.anl.gov> wrote:
> I dont know what to do, re:
I mean literally do the globusrun thing.
> On 2/10/09 6:47 PM, Mihael Hategan wrote:
> > On Mon, 2009-02-09 at 18:23 -0600, Michael Wilde wrote:
> >> It sounds reasonable, but lets try it and see how well it works.
> > http://www.ci.uchicago.edu/~hategan/coaster-bootstrap.jar.pl
> OK, fetched that.
> Is there a patch for this? Modifed ServiceManager to use this for
> bootstrapping?
There is no patch. Just that script.
> > I suggest trying
> > globusrun perl -e "`cat coaster-bootstrap.jar.pl`"
> Do you mean put perl, -e, and the contents of the .pl file into an RSL
> string and run through globusrun?
That would do. But I suspect the above command will do that.
> on the command line gives what you show below.
Yes, that I checked.
The point is to run the same through a few job managers and see
whether they choke on it or not. If it goes through as many sites
as we can send to, then we declare this a winner.
If not, we go back to the drawing board.
