[Swift-devel] Re: which foo
Mihael Hategan
hategan at mcs.anl.gov
Mon Feb 9 13:03:39 CST 2009
Not a very good idea. Back to where I was.
On Mon, 2009-02-09 at 12:09 -0600, Mihael Hategan wrote:
> This is getting too annoying. Too much variation. So I'm exploring
> embedding the bootstrap jar into the script so that the only thing the
> script needs to do is find java (no md5 check and no wget).
> On Mon, 2009-02-09 at 10:52 -0600, Michael Wilde wrote:
> > also, the case where java is not found either initially or after testing
> > with "bash -l" yields a dirname error, I think. I didnt have time to
> > gather the output of that, but its easy to see where it happens.
> > that was the case on teraport to the osg vo using the service-on-worker
> > patch.
> > On 2/9/09 10:25 AM, Ben Clifford wrote:
> > > ... though thats easy to get around with a test for executableness of the
> > > output, which I have done in my local checkout.
> > > The curl support is broken elsewhere, in its use of -O instead of -o,
> > > which I am also fixing.
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
