[Swift-devel] Re: which foo
    Mihael Hategan
    hategan at mcs.anl.gov
    Mon Feb  9 12:09:22 CST 2009
This is getting too annoying. Too much variation. So I'm exploring
embedding the bootstrap jar into the script so that the only thing the
script needs to do is find java (no md5 check and no wget).
On Mon, 2009-02-09 at 10:52 -0600, Michael Wilde wrote:
> also, the case where java is not found either initially or after testing
> with "bash -l" yields a dirname error, I think. I didnt have time to
> gather the output of that, but its easy to see where it happens.
> that was the case on teraport to the osg vo using the service-on-worker
> patch.
> On 2/9/09 10:25 AM, Ben Clifford wrote:
> > ... though thats easy to get around with a test for executableness of the
> > output, which I have done in my local checkout.
> > The curl support is broken elsewhere, in its use of -O instead of -o,
> > which I am also fixing.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
