[Swift-devel] strange behavior evaluating function call as trace arg
Ben Clifford
benc at hawaga.org.uk
Mon Feb 9 08:59:14 CST 2009
I committed your original patch and my fix as r2520.
On Sun, 8 Feb 2009, Ben Clifford wrote:
> On Sat, 7 Feb 2009, Mihael Hategan wrote:
> > Here's a patch. It allows procedure invocations in expressions.
> > http://www.ci.uchicago.edu/~hategan/invoke-proc.patch
> In the test in the below patch, I get a conflict with the use of $ for
> more than one purpose. The use in the nested procedure call upsets
> getThreadPrefix which is expecting it to contain something else (if it
> exists). Renaming that variable (as the below patch does) makes the test
> run ok for me.
> http://www.ci.uchicago.edu/~benc/invoke-proc-test-fix-1
> (its not a very good test as it doesn't check the output is correct, but
> it suffices for the purposes of this precise bug)
