[Swift-devel] strange behavior evaluating function call as trace arg
Ben Clifford benc at hawaga.org.uk
Sun Feb 8 05:28:32 CST 2009
On Sat, 7 Feb 2009, Mihael Hategan wrote:
> Here's a patch. It allows procedure invocations in expressions.
> http://www.ci.uchicago.edu/~hategan/invoke-proc.patch
In the test in the below patch, I get a conflict with the use of $ for
more than one purpose. The use in the nested procedure call upsets
getThreadPrefix which is expecting it to contain something else (if it
exists). Renaming that variable (as the below patch does) makes the test
run ok for me.
http://www.ci.uchicago.edu/~benc/invoke-proc-test-fix-1
(its not a very good test as it doesn't check the output is correct, but
it suffices for the purposes of this precise bug)
