[Swift-devel] coasters on UC teraport with head job running on a worker node
Michael Wilde
wilde at mcs.anl.gov
Fri Feb 6 12:27:21 CST 2009
I tested it, and it worked - very nice.
I like the idea of moving the service load to a worker when possible.
So this patch gets around the problem of managed-fork/condor jobmanager
by submitting to the pbs jobmanager instead of fork.
But that means that to generalize this, we still need to solve the
problem of running the service bootstrap.sh if the cluster is a condor
pool, right?
- Mike
On 2/6/09 11:50 AM, Ben Clifford wrote:
> I hacked around with coasters here to see about getting the head job
> running on a cluster worker node rather than on the cluster head node.
> This works on teraport through PBS. The below patch contains the changes I
> made to make that happen.
> http://www.ci.uchicago.edu/~benc/tmp/coaster-head-elsewhere
> There are three changes I made:
> i) submit to pbs jobmanager instead of to fork jobmanager
> ii) start coaster workers with IP address of the head-worker node
> instead of the address of the cluster head node
> iii) hack the environment to point to teraport's CA directory (in the
> environment that I get there, there is no automatically findable
> CA directory, and an ENV profile appeared to not work).
> In situations where the cluster nodes have outbound network connectivity,
> this seems like a nice thing to do, and I want to make this a configurable
> option to go into the SVN.
> I think:
> i) above should probably be an extension to the existing three-field
> coaster jobmanager string, ii) should be a configuration option to go
> along-side the coasterInternalIP setting and iii) should be a more general
> ability to set the environment for a coaster worker.
> Here is the site.xml that I used with this patch:
> <config>
> <pool handle="teraport" >
> <gridftp url="gsiftp://tp-osg.ci.uchicago.edu" />
> <execution provider="coaster" url="tp-osg.ci.uchicago.edu"
> jobManager="gt2:gt2:pbs" />
> <workdirectory >/home/benc/swifttest</workdirectory>
> </pool>
> </config>
