[Swift-devel] coasters on UC teraport with head job running on a worker node
Ben Clifford benc at hawaga.org.uk
Fri Feb 6 11:50:50 CST 2009
I hacked around with coasters here to see about getting the head job
running on a cluster worker node rather than on the cluster head node.
This works on teraport through PBS. The below patch contains the changes I
made to make that happen.
http://www.ci.uchicago.edu/~benc/tmp/coaster-head-elsewhere
There are three changes I made:
    i) submit to pbs jobmanager instead of to fork jobmanager
   ii) start coaster workers with IP address of the head-worker node
       instead of the address of the cluster head node
  iii) hack the environment to point to teraport's CA directory (in the
       environment that I get there, there is no automatically findable
       CA directory, and an ENV profile appeared to not work).
In situations where the cluster nodes have outbound network connectivity,
this seems like a nice thing to do, and I want to make this a configurable
option to go into the SVN.
I think:
i) above should probably be an extension to the existing three-field
coaster jobmanager string, ii) should be a configuration option to go
along-side the coasterInternalIP setting and iii) should be a more general
ability to set the environment for a coaster worker.
Here is the site.xml that I used with this patch:
<config>
  <pool handle="teraport" >
    <gridftp  url="gsiftp://tp-osg.ci.uchicago.edu" />
    <execution provider="coaster" url="tp-osg.ci.uchicago.edu"
jobManager="gt2:gt2:pbs" />
    <workdirectory >/home/benc/swifttest</workdirectory>
  </pool>
</config>
