[Swift-devel] Problems with coasters and managedfork jobmanager
    Mihael Hategan
    hategan at mcs.anl.gov
    Fri Feb  6 10:38:03 CST 2009
I suppose that script could be made newline-less.
On Fri, 2009-02-06 at 10:33 -0600, Michael Wilde wrote:
> I dont know, but I am testing a version where I removed the newlines
> from bootstrap.pl (and adjusted a few bits manually) and I *think* its
> moving on to the next stage and trying to start the workers.
> Ben, it seems that *some* whitespace is passed on OK, in that I can run
> a job that does echo "hello world" and that blank after hello is
> preserved, and the job runs. I assume the whitespace problem is more
> subtle than that?
> On 2/6/09 10:24 AM, Mihael Hategan wrote:
> > On Fri, 2009-02-06 at 16:17 +0000, Ben Clifford wrote:
> >> On Fri, 6 Feb 2009, Mihael Hategan wrote:
> >>> I guess we'll have to stage in the bootstrap script using the stage-in
> >>> directive if we are to support managed fork, since I don't see OSG
> >>> fixing the issue.
> >> They are fixing the whitespace in parameters - see the gram-user thread I
> >> sent in a different message.
> > Does this include the new lines?
