[Swift-devel] Problems with coasters and managedfork jobmanager
Michael Wilde wilde at mcs.anl.gov
Fri Feb 6 10:33:25 CST 2009
I dont know, but I am testing a version where I removed the newlines
from bootstrap.pl (and adjusted a few bits manually) and I *think* its
moving on to the next stage and trying to start the workers.
Ben, it seems that *some* whitespace is passed on OK, in that I can run
a job that does echo "hello world" and that blank after hello is
preserved, and the job runs. I assume the whitespace problem is more
subtle than that?
On 2/6/09 10:24 AM, Mihael Hategan wrote:
> On Fri, 2009-02-06 at 16:17 +0000, Ben Clifford wrote:
>> On Fri, 6 Feb 2009, Mihael Hategan wrote:
>>> I guess we'll have to stage in the bootstrap script using the stage-in
>>> directive if we are to support managed fork, since I don't see OSG
>>> fixing the issue.
>> They are fixing the whitespace in parameters - see the gram-user thread I
>> sent in a different message.
> Does this include the new lines?
