[Swift-devel] gridftp issue in running oops swift script on queenbee
Wenjun Wu wwj at ci.uchicago.edu
Thu Dec 3 16:04:34 CST 2009
I can't find the .info file. The swift engine seems to remove the info
file since the ItFixInit is finished.
Is there any way to tell the swift engine to keep the info file?
Wenjun
> On Thu, 2009-12-03 at 14:31 -0600, Wenjun Wu wrote:
>> Hello,
>>   I got a weird issue in running the attached script on the TeraGrid
>> QueenBee.
>>   The workflow fails after the ItFixInit.sh is done.
>>   The InitFixInit.sh just copies some files to an output directory and
>> it finishes the copying successfully.
>>   But when the swift engine tries to clean up the temp directory for the
>> ItFixInit task, it fails.
>>   I also tries to set the sitedir.keep=true in the swift.properites to
>> avoid the removal of the temp files but got the same error.
> sitedir.keep=true refers to the shared directory not the job directory.
> Anyway, this seems to be some weird issue with the FS.
> What would be helpful would be for you to find the .info file from
> oops-20091202-1700-vmh5dnd3/jobs/j/ItFixInit-jjpe3bk and post that.
