[Swift-devel] RE: [Swift-user] Execution error
    Yue, Chen - BMD
    yuechen at bsd.uchicago.edu
    Thu Apr 30 17:57:40 CDT 2009
Hi Mihael,
The error message is different after I change from gt2:PBS to gt2:gt2:PBS on TACC LoneStar. I attached the trace as following. I don't know if there is still setup problem. Thank you very much!
[yuechen at communicado PTMap2]$ swift PTMap2-unmod.swift -sites.file sites.xml -tc.file tc.data
Swift 0.9rc2 swift-r2860 cog-r2388
RunID: 20090430-1742-tfabq6q4
Progress:
Progress:  Stage in:1
Progress:  Submitting:1
Progress:  Submitted:1
Progress:  Active:1
Failed to transfer wrapper log from PTMap2-unmod-20090430-1742-tfabq6q4/info/r on TACC_LoneStar
Progress:  Active:1
Failed to transfer wrapper log from PTMap2-unmod-20090430-1742-tfabq6q4/info/t on TACC_LoneStar
Progress:  Active:1
Failed to transfer wrapper log from PTMap2-unmod-20090430-1742-tfabq6q4/info/v on TACC_LoneStar
Progress:  Failed:1
Execution failed:
        Exception in PTMap2:
Arguments: [e04.mzXML, ./seqs-ecolik12/fasta02, inputs-unmod.txt, parameters.txt]
Host: TACC_LoneStar
Directory: PTMap2-unmod-20090430-1742-tfabq6q4/jobs/v/PTMap2-v7baq5aj
stderr.txt:
stdout.txt:
Caused by:
        Cannot submit job
org.globus.cog.abstraction.impl.common.task.TaskSubmissionException: Cannot submit job
        at org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.submitSingleJob(JobSubmissionTaskHandler.java:145)
        at org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.submit(JobSubmissionTaskHandler.java:99)
        at org.globus.cog.abstraction.impl.common.AbstractTaskHandler.submit(AbstractTaskHandler.java:46)
        at org.globus.cog.abstraction.impl.common.task.ExecutionTaskHandler.submit(ExecutionTaskHandler.java:43)
        at org.globus.cog.abstraction.coaster.service.job.manager.WorkerManager.startWorker(WorkerManager.java:221)
        at org.globus.cog.abstraction.coaster.service.job.manager.WorkerManager.run(WorkerManager.java:145)
Caused by: org.globus.gram.GramException: The gatekeeper failed to find the requested service
        at org.globus.gram.Gram.checkHttpReply(Gram.java:137)
        at org.globus.gram.Gram.request(Gram.java:342)
        at org.globus.gram.GramJob.request(GramJob.java:262)
        at org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.submitSingleJob(JobSubmissionTaskHandler.java:133)
        ... 5 more
Cleaning up...
Shutting down service at https://129.114.50.32:35257
Got channel MetaChannel: 13391897 -> GSSSChannel-null(1)
- Done
Chen, Yue
From: Mihael Hategan [mailto:hategan at mcs.anl.gov]
Sent: Thu 4/30/2009 5:37 PM
To: Yue, Chen - BMD
Cc: Michael Wilde; swift-devel
Subject: RE: [Swift-devel] RE: [Swift-user] Execution error
On Thu, 2009-04-30 at 17:32 -0500, Yue, Chen - BMD wrote:
> Hi Michael,
> I already have +osg-client-1.0.0-r1 in my .soft file. But I change it
> to +osg-client and tried again. "ranger" gave me the same error
> message. In the meantime, I tested one job on both Abe and Lonestar
> and they both gave me qsub error.
Can you try "gt2:gt2:PBS" instead of "gt2:PBS" on all sites?
>  I attached as following:
> RunID: 20090430-1722-oncfdolb
> Progress:
> PTMap2-unmod-20090430-1722-oncfdolb/info/3 on TACC_LoneStar
> Progress:  Active:1
> PTMap2-unmod-20090430-1722-oncfdolb/info/5 on TACC_LoneStar
> Progress:  Active:1
> PTMap2-unmod-20090430-1722-oncfdolb/info/7 on TACC_LoneStar
> Progress:  Failed:1
> Execution failed:
> parameters.txt]
> Host: TACC_LoneStar
> Directory: PTMap2-unmod-20090430-1722-oncfdolb/jobs/7/PTMap2-7uagp5aj
> stderr.txt:
> stdout.txt:
> Caused by:
>         Cannot submit job: Could not submit job (qsub reported an exit
> code of -1). no error output
> Cannot submit job: Could not submit job (qsub reported an exit code of
>         at
> org.globus.cog.abstraction.impl.scheduler.common.AbstractJobSubmissionTaskHandler.submit(AbstractJobSubmissionTaskHandler.java:63)
>         at
>         at
>         at
>         at
> Caused by:
> org.globus.cog.abstraction.impl.scheduler.common.ProcessException:
> Could not submit job (qsub reported an exit code of -1). no error
> output
>         at
> org.globus.cog.abstraction.impl.scheduler.common.AbstractExecutor.start(AbstractExecutor.java:94)
>         at
> org.globus.cog.abstraction.impl.scheduler.common.AbstractJobSubmissionTaskHandler.submit(AbstractJobSubmissionTaskHandler.java:53)
>         ... 4 more
> Cleaning up...
> Shutting down service at https://129.114.50.32:34704 <https://129.114.50.32:34704/>
> Got channel MetaChannel: 2013263 -> GSSSChannel-null(1)
> - Done
> My sites.xml is at : /home/yuechen/PTMap2/sites.xml. I'm wondering if
> this still relates to my setup. Thanks!
> Chen, Yue
This email is intended only for the use of the individual or entity to which it is addressed and may contain information that is privileged and confidential. If the reader of this email message is not the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication is prohibited. If you have received this email in error, please notify the sender and destroy/delete all copies of the transmittal. Thank you.
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20090430/18621f4a/attachment.html>
