[Swift-devel] feature request
    Zhao Zhang
    zhaozhang at uchicago.edu
    Wed Apr 29 11:05:20 CDT 2009
Ha, I see. Thanks.
Here comes another issue:
[zzhang at tp-grid1 sites]$ ./run-site condor-g/test-RENCI-Engagement.xml
testing site configuration: condor-g/test-RENCI-Engagement.xml
Removing files from previous runs
Running test 061-cattwo at Wed Apr 29 11:02:05 CDT 2009
Swift 0.9rc2 swift-r2860 cog-r2388
RunID: 20090429-1102-jsx6fqzc
Progress:
Progress:  Initializing site shared directory:1
Execution failed:
        Could not initialize shared directory on localhost
Caused by:
        org.globus.cog.abstraction.impl.file.FileResourceException:
Cannot create directory
/nfs/osg-data/engage/tmp/RENCI-Engagement/061-cattwo-20090429-1102-jsx6fqzc
Caused by:
        Server refused performing the request. Custom message: Server
refused creating directory (error code 1) [Nested exception message:
Custom message: Unexpected reply: 500-Command failed :
globus_gridftp_server_file.c:globus_l_gfs_file_mkdir:554:
500-System error in mkdir: Permission denied
500-A system call failed: Permission denied
500 End.]
SWIFT RETURN CODE NON-ZERO - test 061-cattwo
So, the default workdirecory doesn't have wirte access, is there a
pattern on OSG that I could know where I could write to?
zhao
Michael Wilde wrote:
> The message:
> Could not find any valid host for task "Task(type=UNKNOWN,
> identity=urn:cog-1241018496704)" with constraints
> {filenames=[Ljava.lang.String;@7f38f3d1, trfqn=cat,
> filecache=org.griphyn.vdl.karajan.lib.cache.CacheMapAdapter at 740f5f97,
> tr=cat}
> means there was no tc.data entry for cat on any site.
> So I suspect this is due to your pool handles not natching your
> tc.data site names.
> On 4/29/09 10:35 AM, Zhao Zhang wrote:
>> Hi, again.
>> Now I have two sites.xml for renci-engagement. The first one is
>> working, while the second is not. The second sites.xml is generated
>> by the script.
>> Since the only difference between the first and the second is the
>> <workdirectory> value, I am assuming the error is caused by the
>> <workdirectory>.
>> If this is true, how could I find all valid <workdirectory> for all
>> sites on OSG?
>> zhao
>> First:
>> <config>
>>   <pool handle="renci-engage">
>>      <gridftp  url="gsiftp://belhaven-1.renci.org/" />
>>      <execution provider="condor" />
>>      <workdirectory >/nfs/home/osgedu/benc</workdirectory>
>>      <profile namespace="globus" key="jobType">grid</profile>
>>      <profile namespace="globus" key="gridResource">gt2
>> belhaven-1.renci.org/jobmanager-fork</profile>
>>   </pool>
>> </config>
>> Second:
>> <config>
>>  <!-- RENCI-Engagement -->
>>  <pool handle="RENCI-Engagement" >
>>    <workdirectory
>>  >/nfs/osg-data/engage/tmp/RENCI-Engagement</workdirectory>
>>  </pool>
>> </config>
>> The error message is:
>> [zzhang at tp-grid1 sites]$ ./run-site condor-g/RENCI-Engagement.xml
>> testing site configuration: condor-g/RENCI-Engagement.xml
>> Running test 061-cattwo at Wed Apr 29 10:21:31 CDT 2009
>> RunID: 20090429-1021-8ayf7v75
>> Progress:
>> Execution failed:
>> tr=cat}
>> Ben Clifford wrote:
>>> On Wed, 29 Apr 2009, Zhao Zhang wrote:
>>>> I modified the existing swift-osg-ress-site-catalog, and generate a
>>>> sample
>>>> sites.xml at CI network
>>>> /home/zzhang/swift_coaster/cog/modules/swift/tests/sites/condor-g/sample-sites.xml
>>>> Could you help me check if there is any known error in there? thanks.
>>> I looked briefly and it seems ok
