[Swift-devel] feature request
    Zhao Zhang
    zhaozhang at uchicago.edu
    Wed Apr 29 10:35:07 CDT 2009
Hi, again.
Now I have two sites.xml for renci-engagement. The first one is working,
while the second is not. The second sites.xml is generated by the script.
Since the only difference between the first and the second is the
<workdirectory> value, I am assuming the error is caused by the
<workdirectory>.
If this is true, how could I find all valid <workdirectory> for all
sites on OSG?
zhao
First:
<config>
   <pool handle="renci-engage">
      <gridftp  url="gsiftp://belhaven-1.renci.org/" />
      <execution provider="condor" />
      <workdirectory >/nfs/home/osgedu/benc</workdirectory>
      <profile namespace="globus" key="jobType">grid</profile>
      <profile namespace="globus" key="gridResource">gt2
belhaven-1.renci.org/jobmanager-fork</profile>
   </pool>
</config>
Second:
<config>
  <!-- RENCI-Engagement -->
  <pool handle="RENCI-Engagement" >
    <workdirectory
 >/nfs/osg-data/engage/tmp/RENCI-Engagement</workdirectory>
  </pool>
</config>
The error message is:
[zzhang at tp-grid1 sites]$ ./run-site condor-g/RENCI-Engagement.xml
testing site configuration: condor-g/RENCI-Engagement.xml
Removing files from previous runs
Running test 061-cattwo at Wed Apr 29 10:21:31 CDT 2009
Swift 0.9rc2 swift-r2860 cog-r2388
RunID: 20090429-1021-8ayf7v75
Progress:
Execution failed:
        Could not find any valid host for task "Task(type=UNKNOWN,
identity=urn:cog-1241018496704)" with constraints
{filenames=[Ljava.lang.String;@7f38f3d1, trfqn=cat,
filecache=org.griphyn.vdl.karajan.lib.cache.CacheMapAdapter at 740f5f97,
tr=cat}
SWIFT RETURN CODE NON-ZERO - test 061-cattwo
Ben Clifford wrote:
> On Wed, 29 Apr 2009, Zhao Zhang wrote:
>> I modified the existing swift-osg-ress-site-catalog, and generate a sample
>> sites.xml at CI network
>> /home/zzhang/swift_coaster/cog/modules/swift/tests/sites/condor-g/sample-sites.xml
>> Could you help me check if there is any known error in there? thanks.
> I looked briefly and it seems ok
