[Swift-devel] feature request
    Zhao Zhang
    zhaozhang at uchicago.edu
    Tue Apr 28 15:00:40 CDT 2009
Hi, Ben
Is this the following a correct condor-G sites.xml ?
zhao
<config>
  <pool handle="renci-engage" >
    <gridftp  url="gsiftp://belhaven-1.renci.org/" />
    <execution provider="gt4" jobmanager="condor"
url="belhaven-1.renci.org:2119/jobmanager-condor"/>
    <workdirectory >/nfs/osg-data/osgedu/benc/swift</workdirectory>
  </pool>
</config>
Ben Clifford wrote:
> On Fri, 24 Apr 2009, Michael Wilde wrote:
>> Testing of the new condor provider features is important.
> I would be interested in seeing the condor-g changes tested against a
> large set of OSG sites. However, the swift/ress/osg site file generator
> does not generate sites files to use that. If you (Zhao) want to modify
> the sites file generator to give sites.xml files that use the condor
> provider in condor-g mode, instead of using the gt2 provider, then you
> would be able to get some testing done on OSG; or you could generate the
> sites file by hand based on the output of swift-osg-ress-site-catalog.
