[Swift-devel] feature request
    Ben Clifford
    benc at hawaga.org.uk
    Tue Apr 28 07:49:30 CDT 2009
On Fri, 24 Apr 2009, Michael Wilde wrote:
> Testing of the new condor provider features is important.
I would be interested in seeing the condor-g changes tested against a
large set of OSG sites. However, the swift/ress/osg site file generator
does not generate sites files to use that. If you (Zhao) want to modify
the sites file generator to give sites.xml files that use the condor
provider in condor-g mode, instead of using the gt2 provider, then you
would be able to get some testing done on OSG; or you could generate the
sites file by hand based on the output of swift-osg-ress-site-catalog.
