[Swift-devel] progress stats lying
    Mihael Hategan
    hategan at mcs.anl.gov
    Tue Apr 28 13:30:41 CDT 2009
On Tue, 2009-04-28 at 13:25 -0500, Glen Hocky wrote:
> Agreed. but if they are inaccurate then it is as bad as not having them
> at all.
Maybe worse even.
> Mihael Hategan wrote:
> > On Tue, 2009-04-28 at 13:05 -0500, Glen Hocky wrote:
> >> as a user, it seems very important to have accurate summary stats so you
> >> can tell if anything is going wrong.
> > You're overgeneralizing. You can infer some things from the summary
> > stats, but many things can go wrong even though the summary stats are
> > right.
> >>> On Tue, 2009-04-28 at 07:15 +0000, Ben Clifford wrote:
> >>>> On Tue, 28 Apr 2009, Ben Clifford wrote:
> >>>>>> A possible solution is to add another state ("Checking status" or
> >>>>>> something), that is triggered in Execute by a task completed event.
> >>>> r2887 adds a checking status event in execute2, right after the
> >>>> vdl:execute call. I think that is sufficient? or are you claiming that
> >>>> something deeper in the execute layer is delaying things?
> >>> It's probably better but not sufficient. With many threads there may be
> >>> delays between the vdl:execute call completing and the next thing
> >>> running may be visible.
> >>> The problem is that swift may say that more jobs are active than known
> >>> possible, which will raise eyebrows.
> >>> _______________________________________________
> >>> Swift-devel mailing list
> >>> Swift-devel at ci.uchicago.edu
> >>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
