[Swift-devel] Avoid copy of local files to work directory?
    Ben Clifford
    benc at hawaga.org.uk
    Thu Apr 23 03:31:43 CDT 2009
On Thu, 23 Apr 2009, Gabri Turcu wrote:
> http://people.cs.uchicago.edu/~gabri/concurrent_mapper/ and
I looked at
http://people.cs.uchicago.edu/~gabri/concurrent_mapper/report-count-20090422-1853-c819lhq7/karajan.html
and it doesn't look like the file transfer stuff is using up a large
portion of time.
The graphs in the karjan tab "karajan FILE_TRANSFER tasks" show most of
the time no file transfer are happening. If that stagein/stageout step was
taking a lot of time, then I would expect that to be a solid red block
showing that the file transfer throttle was being reached often.
Similarly on the info tab, the graph 'how wrapper.sh is spending its time'
and manual observation of a few randomly chosen info files shows that
hardly any time is being used on input file management compared to
execution time.
It has been suggested that there is a problem with input file staging
taking too long, but the above log file seems to suggest that this is not
at all a problem.
Please can you (plural - whoever it is that thinks file staging is a
problem here) present some specific evidence to convince me?
