[Swift-devel] Avoid copy of local files to work directory?
    Gabri Turcu
    gabri.turcu at gmail.com
    Thu Apr 23 02:06:16 CDT 2009
Hi Ben,
The more recent logs in
http://people.cs.uchicago.edu/~gabri/concurrent_mapper/ and
http://people.cs.uchicago.edu/~gabri/simple_mapper/ were done with the
wrapperlog.always.transfer = true. I have put the properties file I was
using for these at
http://people.cs.uchicago.edu/~gabri/count.prop
I will restart the large run too with this setting and get back. Thanks a
lot.
Best,
Gabri
On Thu, Apr 23, 2009 at 1:47 AM, Ben Clifford <benc at hawaga.org.uk> wrote:
> Can you do a run with swift.properties option
> wrapperlog.always.transfer=true (it is set to false by default).
> There is interesting timing data in there.
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20090423/b5b1860f/attachment.html>
