[Swift-devel] swift not working
    Michael Andric
    andric at uchicago.edu
    Tue Apr 21 13:58:16 CDT 2009
do you have a full path for this?  "examples/swift/first.swift "
On Tue, Apr 21, 2009 at 1:00 PM, Ben Clifford <benc at hawaga.org.uk> wrote:
> Unlike the other two, I can talk to bigred manually ok. I can also run
> examples/swift/first.swift OK on bigred.
> Please try running examples/swift/first.swift against bigred from your
> setup.
> Also send the swift version string from the start of swift output.
> On Tue, 21 Apr 2009, Michael Andric wrote:
> > just tried on bigred - also failed
> > Progress: Failed but can retry:3
> > Progress:  Stage in:1 Failed but can retry:2
> > Exception occured in the exception handling code, so it cannot be
> properly
> > propagated to the user
> > java.net.SocketException: Broken pipe
> >         at java.net.SocketOutputStream.socketWrite0(Native Method)
> >         at
> > java.net.SocketOutputStream.socketWrite(SocketOutputStream.java:92)
> >         at java.net.SocketOutputStream.write(SocketOutputStream.java:115)
> >         at java.io.DataOutputStream.writeByte(DataOutputStream.java:136)
> >         at
> org.globus.ftp.dc.EBlockImageDCWriter.endOfData(EBlockImageDCWriter.java:63)
> >         at
> org.globus.ftp.dc.GridFTPTransferSourceThread.shutdown(GridFTPTransferSourceThread.java:62)
> >         at
> > org.globus.ftp.dc.TransferSourceThread.run(TransferSourceThread.java:87)
> > Failed to transfer wrapper log from AFNIsnr-20090421-1220-q9598ll1/info/o
> on
> > BIGRED
> > Progress:  Failed:1 Failed but can retry:2
> > Execution failed:
> >         Exception in AFNI_3dvolreg:
> > Arguments: [-twopass, -twodup, -dfile, mot_RFL2.run4_trim, -base,
> > ts.4_trim+orig[92], -prefix, volreg.RFL2.run4_trim, ts.4_trim+orig.BRIK]
> > Host: BIGRED
> > Directory: AFNIsnr-20090421-1220-q9598ll1/jobs/o/AFNI_3dvolreg-od58kp9j
> > stderr.txt:
> > stdout.txt:
> > Caused by:
> >         Server refused performing the request. Custom message:  (error
> code
> > 1) [Nested exception message:  Custom message: Unexpected reply: 451
> ocurred
> > during retrieve()
> > org.globus.ftp.exception.ServerException: Refusing to start transfer
> before
> > previous transfer completes (error code 5)
> before
> >         at
> org.globus.ftp.dc.TransferThreadManager.startTransfer(TransferThreadManager.java:129)
> >         at
> org.globus.ftp.extended.GridFTPServerFacade.retrieve(GridFTPServerFacade.java:431)
> >         at org.globus.ftp.FTPClient.put(FTPClient.java:1289)
> >         at
> org.globus.cog.abstraction.impl.file.gridftp.old.FileResourceImpl.putFile(FileResourceImpl.java:427)
> >         at
> org.globus.cog.abstraction.impl.fileTransfer.DelegatedFileTransferHandler.doDestination(DelegatedFileTransferHandler.java:355)
> >         at
> org.globus.cog.abstraction.impl.fileTransfer.CachingDelegatedFileTransferHandler.doDestination(CachingDelegatedFileTransferHandler.java:47)
> >         at
> org.globus.cog.abstraction.impl.fileTransfer.DelegatedFileTransferHandler.run(DelegatedFileTransferHandler.java:492)
> >         at java.lang.Thread.run(Thread.java:595)
> > gwynn 4%
> > On Tue, Apr 21, 2009 at 12:25 PM, Mihael Hategan <hategan at mcs.anl.gov
> >wrote:
> > > Ok. My point was, in general, that if there are such catastrophic
> > > failures, spacing out in time a couple of attempts generally raises the
> > > confidence that the problem is not some spooky transient issue.
> > > On Tue, 2009-04-21 at 17:19 +0000, Ben Clifford wrote:
> > > > I can recreate non-swift brokenness on both of those sites.
> > > > On Tue, 21 Apr 2009, Mihael Hategan wrote:
> > > > > Did you also try that one again?
> > > > > On Tue, 2009-04-21 at 12:14 -0500, Michael Andric wrote:
> > > > > > what about ucanl?
> > > > > > On Tue, Apr 21, 2009 at 12:11 PM, Ben Clifford <
> > > > > >         > /disks/ci-gpfs/fmri/cnari/config/sites_bsd.xml
> > > > > >         I cannot make a manual submission to
> gwynn.bsd.uchicago.edu
> > > > > >         using
> > > > > >         globus-job-run, so this is not a Swift problem. I think
> this
> > > > > >         is something
> > > > > >         that support at ci should deal with.
> > > > > > _______________________________________________
> > > > > > Swift-devel mailing list
> > > > > > Swift-devel at ci.uchicago.edu
> > > > > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20090421/234c7680/attachment.html>
