[Swift-devel] swift not working
    Ben Clifford
    benc at hawaga.org.uk
    Tue Apr 21 13:00:51 CDT 2009
Unlike the other two, I can talk to bigred manually ok. I can also run
examples/swift/first.swift OK on bigred.
Please try running examples/swift/first.swift against bigred from your
setup.
Also send the swift version string from the start of swift output.
On Tue, 21 Apr 2009, Michael Andric wrote:
> just tried on bigred - also failed
> Progress: Failed but can retry:3
> Progress:  Stage in:1 Failed but can retry:2
> Exception occured in the exception handling code, so it cannot be properly
> propagated to the user
> java.net.SocketException: Broken pipe
>         at java.net.SocketOutputStream.socketWrite0(Native Method)
>         at
> java.net.SocketOutputStream.socketWrite(SocketOutputStream.java:92)
>         at java.net.SocketOutputStream.write(SocketOutputStream.java:115)
>         at java.io.DataOutputStream.writeByte(DataOutputStream.java:136)
>         at
> org.globus.ftp.dc.EBlockImageDCWriter.endOfData(EBlockImageDCWriter.java:63)
>         at
> org.globus.ftp.dc.GridFTPTransferSourceThread.shutdown(GridFTPTransferSourceThread.java:62)
>         at
> org.globus.ftp.dc.TransferSourceThread.run(TransferSourceThread.java:87)
> Failed to transfer wrapper log from AFNIsnr-20090421-1220-q9598ll1/info/o on
> BIGRED
> Progress:  Failed:1 Failed but can retry:2
> Execution failed:
>         Exception in AFNI_3dvolreg:
> Arguments: [-twopass, -twodup, -dfile, mot_RFL2.run4_trim, -base,
> ts.4_trim+orig[92], -prefix, volreg.RFL2.run4_trim, ts.4_trim+orig.BRIK]
> Host: BIGRED
> Directory: AFNIsnr-20090421-1220-q9598ll1/jobs/o/AFNI_3dvolreg-od58kp9j
> stderr.txt:
> stdout.txt:
> Caused by:
>         Server refused performing the request. Custom message:  (error code
> 1) [Nested exception message:  Custom message: Unexpected reply: 451 ocurred
> during retrieve()
> org.globus.ftp.exception.ServerException: Refusing to start transfer before
> previous transfer completes (error code 5)
>         at
> org.globus.ftp.dc.TransferThreadManager.startTransfer(TransferThreadManager.java:129)
>         at
> org.globus.ftp.extended.GridFTPServerFacade.retrieve(GridFTPServerFacade.java:431)
>         at org.globus.ftp.FTPClient.put(FTPClient.java:1289)
>         at
> org.globus.cog.abstraction.impl.file.gridftp.old.FileResourceImpl.putFile(FileResourceImpl.java:427)
>         at
> org.globus.cog.abstraction.impl.fileTransfer.DelegatedFileTransferHandler.doDestination(DelegatedFileTransferHandler.java:355)
>         at
> org.globus.cog.abstraction.impl.fileTransfer.CachingDelegatedFileTransferHandler.doDestination(CachingDelegatedFileTransferHandler.java:47)
>         at
> org.globus.cog.abstraction.impl.fileTransfer.DelegatedFileTransferHandler.run(DelegatedFileTransferHandler.java:492)
>         at java.lang.Thread.run(Thread.java:595)
> gwynn 4%
> On Tue, Apr 21, 2009 at 12:25 PM, Mihael Hategan <hategan at mcs.anl.gov>wrote:
> > Ok. My point was, in general, that if there are such catastrophic
> > failures, spacing out in time a couple of attempts generally raises the
> > confidence that the problem is not some spooky transient issue.
> > On Tue, 2009-04-21 at 17:19 +0000, Ben Clifford wrote:
> > > I can recreate non-swift brokenness on both of those sites.
> > > On Tue, 21 Apr 2009, Mihael Hategan wrote:
> > > > Did you also try that one again?
> > > > On Tue, 2009-04-21 at 12:14 -0500, Michael Andric wrote:
> > > > > what about ucanl?
> > > > > On Tue, Apr 21, 2009 at 12:11 PM, Ben Clifford <benc at hawaga.org.uk>
> > > > >         > /disks/ci-gpfs/fmri/cnari/config/sites_bsd.xml
> > > > >         I cannot make a manual submission to gwynn.bsd.uchicago.edu
> > > > >         using
> > > > >         globus-job-run, so this is not a Swift problem. I think this
> > > > >         is something
> > > > >         that support at ci should deal with.
> > > > > _______________________________________________
> > > > > Swift-devel mailing list
> > > > > Swift-devel at ci.uchicago.edu
> > > > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
