[Swift-devel] karajan thread IDs as surrogates for swift execution IDs
Ben Clifford benc at hawaga.org.uk
Tue Apr 21 10:23:50 CDT 2009
In the provenance work that I am doing for Swift, I have been using the
karajan thread ID to identify a lot of things, on the assumption that
every distinctly identifiable swift call gets its own karajan thread ID.
This fails in two places: compound procedures which run only a single
statement - in that case, a new karajan thread is not started, and the
same thread is used for both the containing and the contained procedure;
and iterate(){} which runs each iteration in sequence in the same thread.
For the purposes of my immediate development, I have hacks that look like
this:
                        // starting new iteration
+               ThreadingContext tc =
(ThreadingContext)stack.getVar("#thread");
+               stack.setVar("#thread", tc.split(666));
so that the thread ID is different for each iteration (though in a rather
longwinded format using church numerals to number the iterations).
Can I expect things to break or work if I make changes to the thread ID?
Thus far everything seems to be working for me.
