[Swift-devel] coaster block allocations
Michael Wilde wilde at mcs.anl.gov
Fri Apr 17 18:15:18 CDT 2009
Am I doing this wrong?
com$ javac CS.java
CS.java:616: method does not override a method from its superclass
         @Override
CS.java:634: method does not override a method from its superclass
     @Override
CS.java:714: method does not override a method from its superclass
                 @Override
CS.java:719: method does not override a method from its superclass
                 @Override
CS.java:733: method does not override a method from its superclass
                 @Override
5 errors
com$ which javac
/soft/java-1.5.0_06-sun-r1/bin/javac
com$
On 4/17/09 4:33 PM, Mihael Hategan wrote:
> I mentioned a simulator:
> http://www.mcs.anl.gov/~hategan/CS.java
> It will given you a visual idea of how things (will) work (run it and
> press the up key to advance time). You can play with parameters, work
> loads and pre-allocations.
> If you find some behavior that you don't like, send me the parameters
> (which are printed when you close the window) and work load (which
> you'll have to manually paste from the code), so that I can reproduce
> it.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
