[Swift-devel] coaster block allocations
    Mihael Hategan
    hategan at mcs.anl.gov
    Fri Apr 17 16:33:45 CDT 2009
I mentioned a simulator:
http://www.mcs.anl.gov/~hategan/CS.java
It will given you a visual idea of how things (will) work (run it and
press the up key to advance time). You can play with parameters, work
loads and pre-allocations.
If you find some behavior that you don't like, send me the parameters
(which are printed when you close the window) and work load (which
you'll have to manually paste from the code), so that I can reproduce
it.
