[Swift-devel] feature request
Glen Hocky
hockyg at uchicago.edu
Wed Apr 15 14:05:36 CDT 2009
The problem with the first method was that the number of jobs, i.e.
score increased too slowly. In that configuration, i believe that the
behavior was 1 or 2 coasters were submitted to a single site and none to
the others and then it just stayed that way for a long time.
Another problem w/ the default configuration was on sites w/ Coasters
per node > 1. My experience on ranger with the default parameters is
that 2 coasters would start in the queue and only ~6 jobs would run on
them, rather than 32. Since our jobs take ~1 hour, this means that for
32 hours of CPU time, I was getting about 6 CPU hours of work. and even
after jobs started finishing in that config, the ramp up was too slow
Mihael Hategan wrote:
> On Wed, 2009-04-15 at 13:49 -0500, Glen Hocky wrote:
>> Hi Everyone,
>> While I'm thinking of it, one problem I had using coasters on multiple
>> TG sites is that jobs would commit themselves to a site at the beginning
>> of the run.
> If the site scoring parameters are left at the default, only a couple of
> jobs should commit to sites at start, and the number would progressively
> increase as sites complete jobs.
> Combined with replication, which is probably disabled by default, even
> jobs committed to sites that don't do much, should be re-submitted to
> different sites eventually.
>> This was a problem because all of the jobs would finish on
>> one machine while jobs for the other machines were sitting in a queue. I
>> know you may have considered this before, but an option to select a
>> site/coaster for a single job only when one is available would be very
>> useful for us (note: we aren't too worried about overhead in not
>> pre-setting up files and directories because our jobs run > 10 minutes,
>> usually closer to an hour).
> That is one thing that is planned with coasters, but hasn't materialized
> yet, in part due to the fact that the above solution should provide a
> similar experience.
