[Swift-devel] Re: swift + condor-g
    Mihael Hategan
    hategan at mcs.anl.gov
    Mon Apr 13 15:08:32 CDT 2009
On Mon, 2009-04-13 at 20:01 +0000, Ben Clifford wrote:
> It has more serious problems (as in problems that stop it working for me
> entirely) that are perhaps more important to address. The changes I made
> to get it going with condor-g (but some are to make it work with
> condor-anything) are in here:
> http://www.ci.uchicago.edu/~benc/tmp/condor-g.patch
> In summary what I changed to make it run at UJ are:
>  * exit code handling - the in-SVN version expects an exit code file to
> appear but never gets one.
Odd. It was supposed to use the exit code ad.
>  the patch removes that expectation - I haven't
> looked enough to see if it returns exit codes properly or not because
> Swift doesn't care.
>  * LeaveJobInQueue needs to have no + at the start of it (I can't find
> much clear documentation about this on the condor web site)
>  * quoting is kinda screwy (as seems traditional with condor) - what
> breaks running first.swift is for an empty argument, he preent quoting
> behaviour makes the swift wrapper look forinput file called "" rather than
> taking no input files.
What version of condor is that?
> The patch above contains some other mess, as well as the changes I made to
> get it to submit to the OSG CE at UJ.
> On Mon, 13 Apr 2009, Mihael Hategan wrote:
> > That provider I think needs some updating to use job logs instead of the
> > current hold-in-queue-and-then-remove scheme.
> > On Mon, 2009-04-13 at 19:36 +0000, Ben Clifford wrote:
> > > after more fiddling than I was expecting with the cog condor provider and
> > > the condor installation that I'm using, I managed to get first.swift
> > > running through condor-g onto the University of Johannesburg site that I
> > > am working at.
> > > so this looks hopeful.
