[Swift-devel] Re: swift plot
Glen Hocky hockyg at uchicago.edu
Mon Apr 13 09:37:26 CDT 2009
Ah. The falkon provider only shows "submitted" when a job is running and
only returns "active" when a job is staging out (or about to).
Glen
Ben Clifford wrote:
> The graph on the front page 'Number of karajan level job submissions that
> are 'Active'' looks like for the most part only 1 or 2 CPUs were in use at
> any one time.
> That seems not so good - either 1 or 2 CPUs really were in use at any one
> time, which is not good for the app perspective, or maybe the execution
> provider that you are using is not reporting job statuses correctly.
> For comparison, run with:
> wrapperlog.always.transfer=true
> in swift.properties, and make sure that if you move the .log file you move
> the correspondingly named .d directory too, and then plot logs and make
> sure that graphs on the info tab appear (they are broken images at the
> moment).
> That will give a worker-nodes view of how many CPU cores are being used as
> once, for comparison.
